跳转到主内容
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
你所需要的
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 2 中的图像 1,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 2 中的图像 2,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 3 中的图像 1,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 3 中的图像 2,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 3 中的图像 3,3
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 4 中的图像 1,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 4 中的图像 2,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 4 中的图像 3,3
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 5 中的图像 1,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 5 中的图像 2,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 6 中的图像 1,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 6 中的图像 2,3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 步骤 6 中的图像 3,3
    • Carefully remove the battery using a plastic opening tool.
结论
另外一个人完成了本指南。
Vivek Rana
于09/11/21注册
169 声望
撰写一个指南
团队
York University, Team E-23, Melo-Thaiss Fall 2021 York University, Team E-23, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG23
1 名成员
创作了1篇指南
一条评论
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 41
总计 2,227
