跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Asus V6800V RAM Replacement
你所需要的
  1. Asus V6800V RAM Replacement, Battery: 步骤 1 中的图像 1,2 Asus V6800V RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
  3. Asus V6800V RAM Replacement: 步骤 3 中的图像 1,1
    • Locate the RAM chip highlighted in Blue and the two metal tabs holding it in place highlighted in red.
  4. Asus V6800V RAM Replacement: 步骤 4 中的图像 1,1
    • Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
  5. Asus V6800V RAM Replacement: 步骤 5 中的图像 1,1
    • After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
  6. Asus V6800V RAM Replacement: 步骤 6 中的图像 1,1
    • After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
    • Carefully insert the new ram in at the same angle that you removed it at.
    • The other side of the RAM slot is a place for more RAM if you want to put more in. The spaces are highlighted in blue.
结论
Connor
于06/24/10注册
34 声望
撰写一个指南
团队
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G9
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,349
