当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
The actual battery is not pictured.
After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
Carefully insert the new ram in at the same angle that you removed it at.
The other side of the RAM slot is a place for more RAM if you want to put more in.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
