跳转到主内容
Asus ROG Strix GL702VS Motherboard Replacement
你所需要的
  1. Asus ROG Strix GL702VS Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 3 中的图像 1,2 Asus ROG Strix GL702VS Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: 步骤 5 中的图像 1,3 Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: 步骤 5 中的图像 2,3 Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: 步骤 5 中的图像 3,3
    • Remove the four 4.8mm JIS #0 screws (two on each fan).
  6. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 6 中的图像 1,3 Asus ROG Strix GL702VS Motherboard Replacement: 步骤 6 中的图像 2,3 Asus ROG Strix GL702VS Motherboard Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the fan's connector on the motherboard using a pair of tweezers.
    • Be gentle, as the small clips and wires can be easily damaged.
  7. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 7 中的图像 1,2 Asus ROG Strix GL702VS Motherboard Replacement: 步骤 7 中的图像 2,2
    • Gently lift each fan up and out of position.
  8. Asus ROG Strix GL702VS Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Disconnect the screen connector by lightly pulling the clip out.
    • The wires are delicate; disconnecting shouldn't take much force.
  9. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the seven 4mm JIS #0 screws from the motherboard.
    • One may be hidden, requiring disconnecting the screen connector.
  10. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 10 中的图像 1,2 Asus ROG Strix GL702VS Motherboard Replacement: 步骤 10 中的图像 2,2
    • Unscrew the two 6.5mm JIS #0 screws located at the top corners of the motherboard.
  11. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 11 中的图像 1,1
    • Using the opening tool, lift up the flaps that secure the screen to the base.
  12. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 12 中的图像 1,1
    • Disconnect the Wi-Fi antenna by unplugging the black and white wires located behind the ethernet port.
    • For reassembly, note the corresponding triangles for each wire.
  13. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 13 中的图像 1,3 Asus ROG Strix GL702VS Motherboard Replacement: 步骤 13 中的图像 2,3 Asus ROG Strix GL702VS Motherboard Replacement: 步骤 13 中的图像 3,3
    • Use a spudger tool to lift the connector tabs on the motherboard and slide the four ribbons out.
  14. Asus ROG Strix GL702VS Motherboard Replacement: 步骤 14 中的图像 1,2 Asus ROG Strix GL702VS Motherboard Replacement: 步骤 14 中的图像 2,2
    • Grasp the motherboard where the fans are located and lift up.
    • Do not force it. If you feel resistance, restart this guide to ensure you have removed all screws and connectors.
结论
To reassemble the device, follow these instructions in reverse order.
另外一个人完成了本指南。
4条评论
Any recommendation on WHERE to get a replacement mobo for this unit? Not having any luck in tracking one down.
help - 回复
Try ebay -- that's where I got mine.. arrived in a few weeks from China.
turgut kalfaoglu - 回复
What I wonder is that, when replacing the motherboard, should I remove all the aluminium tape that's at the bottom of the case? I suspect some of it has lifted and caused a short previously..
Yes I just replaced the motherboard. There are lots more tips that could have been added here but I used this page to remember where the screws are. Many thanks..
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 1,576
