跳转到主内容
Asus Q503UA-BSI5T17 Fan Removal
你所需要的
  1. Asus Q503UA-BSI5T17 Fan Removal, Battery Replacement: 步骤 1 中的图像 1,1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 Fan Removal: 步骤 2 中的图像 1,2 Asus Q503UA-BSI5T17 Fan Removal: 步骤 2 中的图像 2,2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 Fan Removal: 步骤 3 中的图像 1,3 Asus Q503UA-BSI5T17 Fan Removal: 步骤 3 中的图像 2,3 Asus Q503UA-BSI5T17 Fan Removal: 步骤 3 中的图像 3,3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 Fan Removal, Fan: 步骤 4 中的图像 1,2 Asus Q503UA-BSI5T17 Fan Removal, Fan: 步骤 4 中的图像 2,2
    • Disconnect the two cables connecting the fan to the motherboard.
  5. Asus Q503UA-BSI5T17 Fan Removal: 步骤 5 中的图像 1,2 Asus Q503UA-BSI5T17 Fan Removal: 步骤 5 中的图像 2,2
    • Remove the two screws from the fan with a Phillips #0 screwdriver.
    • Remove the four screws from the heatsink with a Phillips #0 screwdriver.
  6. Asus Q503UA-BSI5T17 Fan Removal: 步骤 6 中的图像 1,1
    • Carefully remove the fan assembly from the laptop.
    • When reinstalling the fan, be sure to clean the contact surfaces on both the CPU and heatsink and reapply fresh thermal paste.
结论
Orlando Garcia
于08/26/19注册
359 声望
创作了2篇指南
团队
Gateway, Team S1-G4, Saknee Fall 2019 Gateway, Team S1-G4, Saknee Fall 2019 的会员
GCC-SAKNEE-F19S1G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 196
