跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Asus Q304UA Hard Drive Replacement
你所需要的
  1. Asus Q304UA Hard Drive Replacement, Remove Bottom Cover: 步骤 1 中的图像 1,1
    • Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
    • Six 9.6 mm screws
    • Four 4.6 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  2. Asus Q304UA Hard Drive Replacement: 步骤 2 中的图像 1,3 Asus Q304UA Hard Drive Replacement: 步骤 2 中的图像 2,3 Asus Q304UA Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
    • Be careful not separate the cover too violently or you will risk breaking the plastic clips that are on the bottom cover.
  3. Asus Q304UA Hard Drive Replacement, Disconnect the battery: 步骤 3 中的图像 1,3 Asus Q304UA Hard Drive Replacement, Disconnect the battery: 步骤 3 中的图像 2,3 Asus Q304UA Hard Drive Replacement, Disconnect the battery: 步骤 3 中的图像 3,3
    • Push metal bracket away from battery connector.
    • Use a spudger to push the battery connection straight up.
    • If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
    • Make sure the computer is powered off before removing the battery.
  4. Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 步骤 4 中的图像 1,3 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 步骤 4 中的图像 2,3 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 步骤 4 中的图像 3,3
    • Disconnect the Wifi/Bluetooth RF cables from the wireless card.
    • Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
  5. Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: 步骤 5 中的图像 1,2 Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: 步骤 5 中的图像 2,2
    • Pull straight up to disconnect the SATA combo cable from the motherboard.
  6. Asus Q304UA Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
    • Two 2.3 mm screws
    • One 5.6 mm screw
  7. Asus Q304UA Hard Drive Replacement: 步骤 7 中的图像 1,3 Asus Q304UA Hard Drive Replacement: 步骤 7 中的图像 2,3 Asus Q304UA Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Tilt the drive up slightly by the connector
    • Remove the SATA combo connector
  8. Asus Q304UA Hard Drive Replacement: 步骤 8 中的图像 1,2 Asus Q304UA Hard Drive Replacement: 步骤 8 中的图像 2,2
    • De-route the SATA and RF cables from the side of the drive bay.
  9. Asus Q304UA Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Insert wisdom here.
  10. Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: 步骤 10 中的图像 1,2 Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: 步骤 10 中的图像 2,2
    • Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
    • Four 3.7 mm screws
  11. Asus Q304UA Hard Drive Replacement: 步骤 11 中的图像 1,3 Asus Q304UA Hard Drive Replacement: 步骤 11 中的图像 2,3 Asus Q304UA Hard Drive Replacement: 步骤 11 中的图像 3,3
    • Peal back thermal cover.
    • Be careful not to tear the cover on the side of the drive as you peel it off.
  12. Asus Q304UA Hard Drive Replacement: 步骤 12 中的图像 1,1
    • Remove drive from hard drive bracket.
结论
3等其他人完成本指南。
iHelpU.Tech
于08/02/17注册
3,558 声望
创作了5篇指南
团队
iHelpU.tech iHelpU.tech 的会员
Business
2 名成员
创作了16篇指南
一条评论
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
Michael Maxson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 23
总计 5,052
