跳转到主内容
Asus G75VW-BHI7N07 USB Port Replacement
你所需要的
  1. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 步骤 1 中的图像 1,3 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 步骤 1 中的图像 2,3 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 步骤 1 中的图像 3,3
    • Remove the screws around the back cover using a Phillips #1 screwdriver.
    • Take the back cover off using the opening tool.
  2. Asus G75VW-BHI7N07 USB Port Replacement: 步骤 2 中的图像 1,3 Asus G75VW-BHI7N07 USB Port Replacement: 步骤 2 中的图像 2,3 Asus G75VW-BHI7N07 USB Port Replacement: 步骤 2 中的图像 3,3
    • Once you get rid of the back cover, spot all the screws marked ‘A’. There should be 10 in total.
    • Remove the battery using the slide release button.
    • This should expose 2 more ‘A’ marked screws.
    • Remove those using the same screwdriver.
  3. Asus G75VW-BHI7N07 USB Port Replacement: 步骤 3 中的图像 1,2 Asus G75VW-BHI7N07 USB Port Replacement: 步骤 3 中的图像 2,2
    • Using the opening tool, remove the disc drive cover.
    • Spot the 6 ‘B’ marked screws and remove them using the Phillips #1 screwdriver.
  4. Asus G75VW-BHI7N07 USB Port Replacement: 步骤 4 中的图像 1,2 Asus G75VW-BHI7N07 USB Port Replacement: 步骤 4 中的图像 2,2
    • Using the opening tool, pry open the keypad platform.
    • You will need to use your hands to get to the laptop’s internal systems by lifting the keypad platform.
  5. Asus G75VW-BHI7N07 USB Port Replacement: 步骤 5 中的图像 1,3 Asus G75VW-BHI7N07 USB Port Replacement: 步骤 5 中的图像 2,3 Asus G75VW-BHI7N07 USB Port Replacement: 步骤 5 中的图像 3,3
    • Now that the fans are exposed, use the opening tool to unhook them at the 4 connecting points.
    • Detach the blue-colored electrical component using the opening tool.
    • Detach the white and black colored electrical component using the opening tool.
  6. Asus G75VW-BHI7N07 USB Port Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #0 Screwdriver, remove the 5 screws around the edges of the motherboard.
    • Remove the 2 screws around the fan using the Phillips #0 Screwdriver which should be near the motherboard.
  7. Asus G75VW-BHI7N07 USB Port Replacement: 步骤 7 中的图像 1,1
    • Carefully lift the motherboard up using the opening tool.
    • You should be able to see the USB port.
    • Now you will be able to desolder the faulty USB port.
    • Here is a link on desoldering 如何焊接和拆焊
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 625
