简介
If your Asus Eee PC 900 LCD display screen is damaged, experiencing pixel issues, or is dim in a bright background, use this guide to replace your display screen.
Prior to making this repair, it is important to confirm that the replacement itself is necessary. Check to make sure that no other solutions are viable. For problems such as pixel issues, inverter issues, or not being able to see color, a full replacement may be necessary.
This guide requires you to remove the battery, keyboard, top cover, and LCD display screen from your Asus Eee PC 900. Some steps require the use of a spudger.
Before beginning, make sure to completely power down the device and disconnect from any external power source.
你所需要的
Identify the three metal tabs holding down the laptop's keyboard.
Using a spudger, depress each metal tab to remove the keyboard.
16等其他人完成本指南。
