简介
The Asus Chromebook C101P only has one item keeping it from overheating. The heat sink is an L-shaped piece of copper that is attached to the CPU on the motherboard to dissipate heat. It is attached using thermal paste so be sure to have some on hand. Ensure that the Chromebook is fully powered off and not plugged in before removing the heat sink. Also, be sure to wait a few minutes after powering off, as the heat sink may be hot.
你所需要的
Flip the Chromebook so that the bottom is facing up.
Remove the nine T5 Torx screws.
在这个步骤中使用的工具:Tweezers$4.99
Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
Separate the keyboard from the rest of the laptop.
