跳转到主内容
Asus CM1745 Heatsink Replacement
你所需要的
  1. Asus CM1745 Heatsink Replacement, Heatsink: 步骤 1 中的图像 1,2 Asus CM1745 Heatsink Replacement, Heatsink: 步骤 1 中的图像 2,2
    • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
  2. Asus CM1745 Heatsink Replacement: 步骤 2 中的图像 1,2 Asus CM1745 Heatsink Replacement: 步骤 2 中的图像 2,2
    • Unplug the CPU fan connector from the motherboard.
    • Then open the latch under the CPU fan and unhook the metal fasteners.
    • Lift the CPU heatsink and cable off of the CPU carefully.
  3. Asus CM1745 Heatsink Replacement: 步骤 3 中的图像 1,3 Asus CM1745 Heatsink Replacement: 步骤 3 中的图像 2,3 Asus CM1745 Heatsink Replacement: 步骤 3 中的图像 3,3
    • Clean both the CPU top and the heatsink bottom by slightly moistening a paper towel with rubbing alcohol and rubbing lightly.
    • Grab your thermal paste and put a pea-sized amount in the middle of the CPU top.
    • Gently replace the heatsink on top of the CPU and re-lock the heatsink fasteners.
    • Replug the CPU Fan connector to the motherboard header.
    • Check out the How to Apply Thermal Paste guide for more details and best practices.
结论
Replug the computer and turn it on. If the fan spins, reattach the sidepanels and the replacement is complete.
TC Fowlar
于10/30/19注册
794 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 441
