跳转到主内容
Astro Pyle PTBL7C Battery Replacement
你所需要的
  1. Astro Pyle PTBL7C  Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use the spudger to open the device from the front edge of the screen. Gently slide it in and push it up to open.
    • It may emit a cracking sound at it opens; this is only the locks coming apart.
  2. Astro Pyle PTBL7C  Battery Replacement: 步骤 2 中的图像 1,2 Astro Pyle PTBL7C  Battery Replacement: 步骤 2 中的图像 2,2
    • The battery will appear as pictured. Separate the back case from the device. Avoid damaging the wire that connects the speakers between the two halves of the case.
  3. Astro Pyle PTBL7C  Battery Replacement: 步骤 3 中的图像 1,1
    • The battery is attached in two different ways; one wire is attached to the screen to support the screen's background led lights. Carefully desolder the wire without damaging the part connecting the battery to the screen.
  4. Astro Pyle PTBL7C  Battery Replacement: 步骤 4 中的图像 1,1
    • Desolder the wires pictured. These feed energy from the battery into the motherboard.
    • Use caution to avoid damaging the motherboard or other critical pieces.
  5. 在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Use a plastic card to gently break the adhesive holding the battery to the metal screen plate. Remove the battery.
    • Though non-functional, the battery still contains dangerous chemicals. Handle it directly as little as possible.
    • Install the new battery and solder all the connections back in place.
    • Visit this guide for more information on soldering and desoldering: iFixit Soldering Guide
结论
Abdulelah
于10/22/16注册
214 声望
创作了2篇指南
团队
IUPUI, Team 5-5, Wilson Fall 2016 IUPUI, Team 5-5, Wilson Fall 2016 的会员
IUPUI-WILSON-F16S5G5
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 397
