跳转到主内容
Astro A50 2016 Headset Motherboard Replacement
你所需要的
  1. Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: 步骤 1 中的图像 1,2 Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: 步骤 1 中的图像 2,2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Motherboard Replacement: 步骤 2 中的图像 1,1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Motherboard Replacement, Headset Motherboard: 步骤 5 中的图像 1,1
  6. Astro A50 2016 Headset Motherboard Replacement: 步骤 6 中的图像 1,2 Astro A50 2016 Headset Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use a soldering iron to desolder the black and yellow wires from the two metal plates near the bottom of the device.
    • Use a soldering iron to desolder the 13 wires in rows along the left and bottom sides of the headset motherboard.
    • 如何焊接和拆焊
  7. Astro A50 2016 Headset Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to pry off the black tape covering the gray wires
  8. Astro A50 2016 Headset Motherboard Replacement: 步骤 8 中的图像 1,1
    • Lift the motherboard out of the headset and gently disconnect the gray wires from the motherboard.
结论
3等其他人完成本指南。
Brian Menard
于10/01/17注册
288 声望
撰写一个指南
团队
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G1
3 名成员
创作了10篇指南
2条评论
Any chance I could get the E250336. USB board part from you guys? I need one.
Theron Miller - 回复
I am having a very tough time finding this Part online. Thanks!
Theron Miller - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 43
总计 4,054
