跳转到主内容
Astro A50 2016 Headset Battery Replacement
你所需要的
  1. Astro A50 2016  Headset Battery Replacement, Headset Speakers: 步骤 1 中的图像 1,2 Astro A50 2016  Headset Battery Replacement, Headset Speakers: 步骤 1 中的图像 2,2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016  Headset Battery Replacement: 步骤 2 中的图像 1,1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016  Headset Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016  Headset Battery Replacement: 步骤 4 中的图像 1,1
    • Lift the speaker module up off the device.
  5. Astro A50 2016  Headset Battery Replacement, Headset Battery: 步骤 5 中的图像 1,2 Astro A50 2016  Headset Battery Replacement, Headset Battery: 步骤 5 中的图像 2,2
    • Remove the five 6mm PH1 screws.
    • Remove the buttons panel by pulling the panel away from the white ribbon cord.
  6. Astro A50 2016  Headset Battery Replacement: 步骤 6 中的图像 1,2 Astro A50 2016  Headset Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the four 6mm PH1 screws.
    • Remove the tape holding the wires connected to the motherboard.
  7. Astro A50 2016  Headset Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the back panel by squeezing the two tabs together and pushing out.
  8. Astro A50 2016  Headset Battery Replacement: 步骤 8 中的图像 1,1
  9. Astro A50 2016  Headset Battery Replacement: 步骤 9 中的图像 1,1
    • Remove the battery by using the plastic opening tool to pry it away from the headset.
结论
14等其他人完成本指南。
Andrew Monson
于10/02/17注册
502 声望
撰写一个指南
团队
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G1
3 名成员
创作了10篇指南
10条评论
Is this for the Gen III Astro a50?
vic.bianco - 回复
Yes it’s for the Gen 3 A50
Crisdavid -
Where do I buy a battery though….
Brandon Phillips - 回复
how can I connect the new battery ?
Ahmed f - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 69
过去 30 天: 332
总计 24,999
