跳转到主内容
Astro A50 (2019) Battery Replacement
你所需要的
  1. Astro A50 (2019) Battery Replacement, Battery: 步骤 1 中的图像 1,2 Astro A50 (2019) Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the right side ear cushion by pulling toward you on the top tab.
  2. Astro A50 (2019) Battery Replacement: 步骤 2 中的图像 1,3 Astro A50 (2019) Battery Replacement: 步骤 2 中的图像 2,3 Astro A50 (2019) Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the speaker filter by using a prying tool and peeling it off.
    • Work your way around the filter until it comes off.
  3. Astro A50 (2019) Battery Replacement: 步骤 3 中的图像 1,3 Astro A50 (2019) Battery Replacement: 步骤 3 中的图像 2,3 Astro A50 (2019) Battery Replacement: 步骤 3 中的图像 3,3
    • Remove all four 1.5 mm screws using the Phillips #00 screwdriver.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. Astro A50 (2019) Battery Replacement: 步骤 4 中的图像 1,3 Astro A50 (2019) Battery Replacement: 步骤 4 中的图像 2,3 Astro A50 (2019) Battery Replacement: 步骤 4 中的图像 3,3
    • Remove all four 1.5 mm screws holding the motherboard using the Phillips #00 screwdriver.
    • Unplug the battery by pulling the plug.
  5. Astro A50 (2019) Battery Replacement: 步骤 5 中的图像 1,2 Astro A50 (2019) Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the old battery with a plastic opening tool.
    • Be careful to not puncture the battery or fold it.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
2等其他人完成本指南。
团队
CSU Los Angeles, Team 11-6, Grodsky Fall 2021 CSU Los Angeles, Team 11-6, Grodsky Fall 2021 的会员
CSULA-GRODSKY-F21S11G6
2 名成员
创作了3篇指南
5条评论
Where did you source the battery for this? Do you have the part number at least? Astro doesn't sell them.
Thomas Garcia - 回复
I am also looking for this without having to get them from china as it will take 4 to 6 weeks to get it. Any local source for this battery?
billy7183 - 回复
I had to order from China, only batteries that are held domestically I could find were for the gen3/solder only and not the connector style
Luft -
For those with a gen3 a50, the battery is mounted slightly different, you don't need to remove the PCB, just pinch the black tabs holding the outer cover on. See here: https://imgur.com/a/m2Nv2Ze
Wouter V - 回复
I performed this battery replacement. I sourced a new battery from another new A50 Gen 4 that was firmware bricked.
I’m having an issue charging the new battery with the base station. The headset does not seem to accept a charge from the base station however it will charge via a micro USB cable plugged into a usb wall brick.
I believe the issue is related to the battery not being calibrated to the old headset. Any ideas?
William Patterson - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 159
过去 30 天: 688
总计 8,853
