简介
Use this guide to replace the display of your bq Aquaris M5.
你所需要的
Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
Take out the seven 4mm Phillips #00 screws, holding the loud speaker unit to the mid frame of the phone.
Use the flat end of a spudger to disconnect the displays flex cable from the mainboard.
Place a suction cup on the bottom-middle part of the screen and lift it up.
Insert the tip of an opening pick in the gap between the display and the midframe.
Slide the opening pick along the edge of the display to cut the adhesive.
Move the opening pick around the top right corner and leave it there.
