简介
使用本指南来更换 Apple Watch Series 4 中的破旧或没电的电池。
本指南显示了标准的仅限GPS版本的手表的操作步骤,但蜂窝/ LTE版本与此类似。
'''为安全起见,在拆卸 Apple Watch 之前,请将电池放电至25%以下。”'如果电池在维修过程中意外损坏,则可降低发生火灾的危险。
注意:如果电池膨胀,如何处理膨胀的电池,请采取适当的预防措施。
在Apple Watch的显示屏打开过程中,可能会损坏强制触摸垫圈。如果分开垫片层或切断电缆,则还需要更换Force Touch垫片本身。
重新组装设备时,你需要使用“替代粘合剂”来重新连接组件。
你所需要的
小心地将屏幕向后折叠,直到有足够的空间撬出电池。
在电池和 Taptic Engine 之间插入撬片。
If you are just replacing the screen then there is no need to remove battery.
When removing the screen I tore the two outer cables attached to the lcd screen. What are their purpose? I read somewhere they are just some sort of shield. Will my watch function normally without them?
thanks
上下翻转 Apple Watch,以便在提起机壳时将显示屏放平。
从显示器背面除去残留的粘合剂。
Und warum soll ich dann bei Amazon 70% Tigern kaufen?
Was genau meinst du?
用镊子小心地从底纸上除去带有蓝色保护膜的替代粘合剂。
The step showing the new battery being installed is missing.
As stated 3 layers. Trick is to separate them correctly and at the right time. The greatest adhesion is to the blue top layer. If done as shown the most difficult task of separating the blue film will be done at the worst time, on the watch. It is better to do the hard part first, separate the blue from the adhesive. So leave the adhesive on the paper backing in the picture above. Then remove the inner part as 3 layers together leaving you with the paper backed adhesive.
斜着握住替换粘合剂,将其穿过显示屏。
稍微向前倾斜显示屏,以便将胶粘剂与框架对齐。
将替换粘合剂放置在 force touch 垫圈的顶部。
See my comments previous step. Instead of blue it should look like the brown paper side with the adhesive down. Now press into the cavity in the watch frame. The paper and cavity will make location easy. You shouldn't have to adjust much. Press the face down on top to squish the adhesive into place. It won't stick because the paper is still on. Open and check placement. Now remove the paper
要重新组装 Apple Watch Series 4,请按照逆序进行操作,以重新安装电池。
为了获得最佳性能,请“校准新安装的电池”:将其充电至100%,并继续充电至少2小时。然后使用你的设备,直到由于电池电量不足而将其关闭。最后,不间断充电至100%。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?请查看我们的社区,以获取疑难解答帮助。
40等其他人完成本指南。
由衷感谢以下译者:
90%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
Hi laws,
iFixit makes no claims to the continued splash-resistance of the Apple Watch after applying this adhesive strip. It's probably going to be just fine, but we can't confirm that the Apple Watch will maintain its IPX7 waterproof rating after being repaired.
Ich habe jetzt 2 Uhren durch - besten Dank für die Hilfestellung. Ich habe mir die “Dichtungs-Klebestreifen” besorgt, waren für mich aber nicht praktikabel. Bei beiden Uhren hat sich die Force-Touch-Dichtung teilweise gelöst und der Klebestreifen hat zwar auf der FT-Dichtung gehalten, aber das Display kam wieder hoch, da der die FT-Dichtung eben nicht mehr am Gehäuse geklebt hat.
Ich habe mir eine Tube Smartphone-Dichtmasse besorgt, damit konnte ich die FT-Dichtung wieder befestigen und habe damit auch das Glas wieder optimal einkleben können. Da sich sich die Masse (wie die Klebestreifen auch) bei Hitze wieder entfernen lässt: für mich die praktikablere Lösung. Auch nicht ganz so frickelig…
Wie heißt der Kleber? T-7000?
Hi. I changed the screen on an apple watch series 4, now the screen works, whcih is great, but when I charge it, the green snake comes on but never charges. It heats up the bottom, gets very warm. Could it be the battery itself? Maybe needs a new one? Is rthere anything else that woudl be causing the battery to not charge and or heat up on the bottom when chaging the screen?
Derrick Brewer - 回复
