跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
Apple Watch Series 2 更换粘合剂
你所需要的
  1. Apple Watch Series 2 更换粘合剂, 清洁: 步骤 1 中的图像 1,2 Apple Watch Series 2 更换粘合剂, 清洁: 步骤 1 中的图像 2,2
    • 在棉签上涂抹一点异丙醇(> 99%酒精)或使用清洁垫轻轻去除力触摸垫片顶部的粘合剂残留物。
    • 要移除显示屏电缆所在侧面的粘合剂,请向下折叠显示屏并小心地将其从框架中拉出,以便有足够的空间。
    I bought 6 adhesive strips expecting to foul up some. I tried following this procedure on three of the sets, but on each set I ended up with one corner not quite long enough to seat properly. On the fourth set I altered the procedure and it finally worked the first time.
    1. Take off the screen. Yes I know, but do it anyway.
    2. Take off only the blue adhesive around the periphery. Do not remove center area.
    3. Place sticky side on force gasket. Seems small, but fit perfectly.
    4. Remove entire inner rectangular portion of adhesive strip
    5. Replace screen
    6. Re-Attach battery
    7. Follow rest of procedure
    marilyntlinton - 回复
    The isopropyl alcohol can only remove so much of the old adhesive. After the first pass with the q-tip use an iFixit Opening Tool to carefully scrape off the old adhesive. There is always some left on the case.
    Vangelis Angelakis - 回复
  2. Apple Watch Series 2 更换粘合剂, 清洁显示屏: 步骤 2 中的图像 1,2 Apple Watch Series 2 更换粘合剂, 清洁显示屏: 步骤 2 中的图像 2,2
    • 翻转 Apple Watch,使显示屏平放,同时抬起外壳。
    • 清洁显示器背面的剩余物。
  3. Apple Watch Series 2 更换粘合剂, 安装新的粘合剂: 步骤 3 中的图像 1,1
    • 使用一把镊子小心地从背纸上用蓝色保护膜去除替换粘合剂。
    Be sure to buy two, three or even more replacement adhesive strips, because depending on the batch or brand, most of them can’t be separated easily, they deform and then they are next to useless.
    @iFixit - Guys check the adhesives you are sending to people. The Tesa ones are simply a nightmare to use.
    Agreed! The strip is EXTREMELY challenging to get off the paper/plastic it comes in - I recommend a very sharp ‘Xacto’, or scalple blade to trim the paper & plastic film (carefully) to allow for the very thin & easily damaged strip from the packaging - let alone getting it place. Vangelis’ adice is sound advice. I had to order two more… (wish me luck)
    Jeff Goodall - 回复
    Thank you both for the heads up! The Tesa brand adhesive was super finicky (my tab broke off pretty early on) but was able to recover with minimal deformation with a blade to remove the unnecessary plastic.
    Felipe Agurto - 回复
  4. Apple Watch Series 2 更换粘合剂: 步骤 4 中的图像 1,2 Apple Watch Series 2 更换粘合剂: 步骤 4 中的图像 2,2
    • 握住替换粘合剂对角以将其穿过显示器。
    • 稍微向前倾斜显示屏,以便将粘合剂与框架对齐。
    • 将替换粘合剂放在力触摸垫片的顶部,并使用撬棒的尖端移动并将其按压到位。
    Den Klebestreifen zu positionieren ist extrem schwer. Teils wegen unzureichender Passgenauigkeit des Klebestreifens, teils weil er ja schon einseitig klebt. Es ist auf jeden Fall hilfreich das AppleWatch-Gehäuse vorher zu fixieren. Ich werde diese Methode nicht ein weiteres mal anwenden, sondern das nächste mal flüssigen Kleber aus der Tube (E-8000 oder vergleichbares) verwenden.
    BjoernImNetz - 回复
    These things are garbage! I’ve replaced the adhesive on 4-5 Apple watches with various cheap Amazon adhesive products. The tab came off on two different ifixit adhesive kits. The first one the white backer would come all the way off the adhesive, so it was worthless. The second one either stretched or was made too long.
    Don’t waste your money. Quality is poor
    the.thams - 回复
  5. Apple Watch Series 2 更换粘合剂: 步骤 5 中的图像 1,1
    • 按照你来自的更换指南中的说明重新连接电池。
    • 轻轻取下粘合剂顶部的保护膜。
    Don’t expect the adhesive strip to follow the edges of the watch’s case. If you try to fit it on the edges on one side, you may end up coming up short on the other, as the above image illustrates. Just try to place it slightly off the edges. It will be ok.
  6. Apple Watch Series 2 更换粘合剂: 步骤 6 中的图像 1,1
    • 对齐屏幕并将其牢牢按在粘合剂上。
    • 为了进一步改善粘合剂的粘合,你可以使用 iOpener 加热显示屏,再将其放置于显示屏上约一分钟。然后施加几个小时的压力(把它放在一到两本书下面一晚上)。
    Buy two clamps, thank me later. Books are good but trust me the clamps are way better. Also expect the screen to wobble ever so slightly after, since the adhesive seems to be a bit elastic in nature.
    Avoid hot or even warm showers to avoid causing the screen to detach from the adhesive.
终点
29等其他人完成本指南。
由衷感谢以下译者:
en zh
66%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,598 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,532篇指南
7条评论
My adhesive gasket I ordered from you doesn’t not look like the one you use. I don’t see how it could work either.
Ryan Hoover - 回复
My adhesive was larger than the rim so it had about 5-6 mm bump of extra plastic when I got it in the edge all around. Need it to be sealed so I didn't want to cut anything. Fail.
Kevin Male - 回复
Yes mine was also larger than the adhesive seal that is advertised here.
Nicholas Goldsworthy - 回复
We believe this adhesive kit does not work all the time. there is still risk that with slightly water in-contact during activity, screen may slightly raised again. I think using glue E-8000 after wiping the edges of the watch with isopropyl is a good idea for long term safety.
iRepairMan - 回复
The Tesa adhesives that you sent are simply aweful. The cuts aren’t deep enough to safely remove the replacement adhesive with the blue protective film from the backing paper. Plus when you actually manage to do so, the adhesive’s dimensions are a bit short for the Series 3 42mm model.
I agree that the adhesive is too small for the series 3 case. Also as noted, you need to use the blade from the kit to carefully go all around cutting the thin strip away from the center piece. Remove the center piece completely first! Putting it in place with the back side backing removed is very difficult! I think if there is a next time that I will remove the backside backing after I have put it in place. Going over the lens and past the cables is impossible without it touching something.
Because of these issues I think I would call this install difficulty HIGH.
Bill Auerbach - 回复
Gasket too big for 42mm watch. Useless.
tom.mckerrow - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 80
过去 30 天: 291
总计 25,168
