当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Lay down the display with screen side up.
Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
Slowly lift the LCD out from its placement and tilt it upwards.
It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
Flip the metal bar over using the tape as a handle.
Next, grab onto the connector and slowly pull it from the socket in the logic board.
The webcam and microphone are located at the top of the device. First, follow the white microphone wire down to its connector in the logic board.
Carefully pull the white wire's connector from the logic board.
The wires are held in place by three pieces of tape. Remove the tape out of the way so that the wires are free.
It is very easy to remove the pieces of tape using tweezers. They aren't completely necessary though.
Back at the top of the device, there are two pieces of silver tape holding the webcam wires in place.
Again, tweezers are helpful but aren't necessary for removal of the silver tape.
Next, remove the tape that is holding the microphone in place.
The webcam is held in with two screws and a connector
Unscrew the two screws holding the webcam in place with the TR 10 screwdriver.
The webcam is now free from your display!
With the webcam removed, the microphone is now visible.
The webcam is held in place with a plastic clip that has foam adhesive stuck to the casing.
Use a plastic spudger to pry underneath the clip and separate the clip from the casing.
The actual microphone itself is stuck to the top of the casing using a small amount of adhesive and covered by a piece of tape.
Remove the piece of tape using either tweezers or your fingers to have access to the microphone.
Use the plastic spudger again to get underneath the small round microphone and pry it loose from the adhesive.
The wires for both the webcam and the microphone are tucked underneath a few other components.
Carefully pull the wires out up and out from the other components and your webcam and microphone can be replaced.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
