本指南有最近更改,您可查看未经巡查的最新版本。
简介
After the LCD is removed, it looks like the webcam and microphone are right within reach. The two wires that are connecting them to the main logic board are behind a lot of the other wires and components making it a little tricky to get to their connectors and take them out. Also, since the microphone is held in by adhesives, a prying tool is absolutely essential to replace it!
你所需要的
The webcam and microphone are located at the top of the device. First, follow the white microphone wire down to its connector in the logic board.
Carefully pull the white wire's connector from the logic board.
The actual microphone itself is stuck to the top of the casing using a small amount of adhesive and covered by a piece of tape.
Remove the piece of tape using either tweezers or your fingers to have access to the microphone.
Use the plastic spudger again to get underneath the small round microphone and pry it loose from the adhesive.
4等其他人完成本指南。
