当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Unplug all cables from the Apple TV before disassembly and flip the device over.
Using the widest plastic opening tool, force its sharp end into the seam between the Apple TV's bottom plate and its outer casing. Starting on the side with the ports, insert the tool so its tip is angled upward when leverage is applied.
Pry the bottom plate away from the case, starting with the edge closest to the bottom of the apple. Work your way around the plate until all clips are disconnected.
With the plastic clips free, lift the bottom plate.
4等其他人完成本指南。
2条评论
Can a replacement logic board be bought online ? What is the part number ?
Thank You
Where can I find a replacement logic board?! I can’t seem to find a website with one anywhere!
David Sein - 回复
