简介
Use this guide to replace a worn-out or dead battery in your Apple TV 4K 2021 Siri Remote. The charging port and the battery of the Siri Remote are connected as one assembly.
你所需要的
Use a P2 Pentalobe screwdriver to remove the two 6.1 mm-long screws securing the bottom cover.
Remove the bottom aluminium cover.
Insert an iFlex into the gap on the right side of the circular clickpad.
Use the iFlex to create a gap by prying the circular clickpad upwards.
Insert an opening pick into the gap. Remove the iFlex after inserting the opening pick.
Slide the opening pick around the top half of the clickpad.
Lift the clickpad from the lower right side to access the press connector.
Use an opening pick to pry up the clickpad connector to disconnect it.
Remove the clickpad.
Insert the iFlex into the gap on the right edge of the volume button.
Insert the iFlex about 3 mm.
Use the iFlex to pry up the volume button to unhinge the plastic clips which keep the button in place.
Remove the volume button.
Use a T3 Torx screwdriver to remove the two 4.7 mm-long screws securing the Siri button on the right edge of the remote.
Turn the remote upside down.
Insert the flat end of a spudger into the charging port.
Push the spudger in to slide the insides of the remote out about 1 inch (2.5 cm).
Turn the remote back over and make sure that the recess of the inner frame aligns with the power button.
Use the pointed end of a spudger to press the power button into the recess of the inner frame (if it didn’t already fall in by itself).
Remove the power button.
Pull the inner frame out of its aluminum housing.
Use a Torx T3 screwdriver to remove the eight 4.7 mm-long screws securing the mainboard to the frame.
Turn over the frame.
Use an opening pick to lift up the small locking flap on the trackpad cable's ZIF connector.
Insert an opening pick on either side of the battery and pry up to lift it away from its recess.
Use the flat end of a spudger to shift the battery port assembly towards the bottom of the frame to free the metal clips holding it in place.
Remove the battery and charging port assembly.
Repair didn’t go as planned? Check out our Answers community for help.
6等其他人完成本指南。
3条评论
Here here, heartily agree.
And, remember: Push comes to shove, you can use your iPhone as a remote as well. Even the Apple Watch. Sortah. The AWU sometimes works, sometimes it doesn't. Works 10~ 20% of the time. You can definitely choose, say, a playlist, start playing from your watch to the AppleTV. Pausing and unpausing, sure. Now, l0hd fohbid you decide to try and control the volume... Or go back one song in the playlist... Or forward... Nope. No can do. But iPhone works "well". Not perfect, but OK.
