跳转到主内容
Apple Powerbook 5300 Hard Drive Replacement
你所需要的
  1. Apple Powerbook 5300 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Hard Drive Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
    • Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
  5. Apple Powerbook 5300 Hard Drive Replacement: 步骤 5 中的图像 1,2 Apple Powerbook 5300 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Unscrew the Torx #8 screws holding the hard drive case in place on the logic board.
    • Lift up on the hard drive to disconnect its ribbon cable from the logic board, just like in the previous steps.
  6. Apple Powerbook 5300 Hard Drive Replacement: 步骤 6 中的图像 1,2 Apple Powerbook 5300 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Unscrew the four Torx #8 screws holding the hard drive to its case.
    • The hard drive can now be removed from its encasement.
结论
2等其他人完成本指南。
Scott
于04/26/11注册
155 声望
创作了5篇指南
团队
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G30
4 名成员
创作了6篇指南
一条评论
I was very surprised to find this guide and very pleased. Good work.
mayer - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 30
总计 6,169
