当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
Unplug the black connector on the top of the metal casing by gently pulling horizontally.
Remove the four 4.3mm phillips screws from the bottom of the metal casing.
Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
To remove the AirPort card, gently pull the plastic tab horizontally.
Locate and remove the three 5.0mm phillips screws from the heat sink.
Lift to remove the heat sink from the motherboard.
Locate and remove the five 7.5mm phillips screws from the motherboard.
Lift and separate the motherboard from the bottom metal casing.
There will be a loose hexagonal female screw extender under the motherboard.
Desolder the six connections located under the USB.
Refer to 如何焊接和拆焊 for soldering techniques.
取消:我没有完成这个指南。
2等其他人完成本指南。
与4其他贡献者
于10/12/11注册
411 声望
创作了5篇指南
徽章: 11
+ 8更多徽章
CPSU-REGAN-F11S17G15
3 名成员
创作了13篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 12
总计 3,127
