跳转到主内容
Apalus Digital Hair Straightening Brush LCD Screen Replacement
你所需要的
  1. Apalus Digital Hair Straightening Brush LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Locate the LED screen on the top side of the circuit board
  6. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Flip the circuit board to start soldering.
  7. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 7 中的图像 1,2 Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Using the soldering tool, melt the solder holding the LCD screen on the circuit board.
    • The screen is soldered in 11 places on the circuit board. Melt each of these points and remove the screen.
    • Soldering Technique Guide
  8. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 8 中的图像 1,2 Apalus Digital Hair Straightening Brush LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Now that the LCD screen is removed, use a soldering tool and solder to install the new screen on the circuit board.
    • Solder at the same 11 points where you previously melted to remove the screen.
结论
Malak
于11/06/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S1-G3, Harley Fall 2017 IUPUI, Team S1-G3, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S1G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 492
