跳转到主内容
Apalus Digital Hair Straightening Brush Heating Element Replacement
你所需要的
  1. Apalus Digital Hair Straightening Brush Heating Element Replacement, Heating Element: 步骤 1 中的图像 1,1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Heating Element Replacement: 步骤 2 中的图像 1,1
    • Turn comb over so the bristles are facing down.
    • Remove backside of the comb and place aside.
  3. Apalus Digital Hair Straightening Brush Heating Element Replacement: 步骤 3 中的图像 1,1
    • Unplug the power cord from the connector inside of the brush.
  4. Apalus Digital Hair Straightening Brush Heating Element Replacement: 步骤 4 中的图像 1,1
    • Remove the circuit board and heating element from the handle.
    • This will provide easy access to the necessary components.
  5. Apalus Digital Hair Straightening Brush Heating Element Replacement: 步骤 5 中的图像 1,1
    • Remove the four 6mm Phillips #2 screws holding the heat shield onto the back side of the bristles.
  6. Apalus Digital Hair Straightening Brush Heating Element Replacement: 步骤 6 中的图像 1,1
    • There are 4 solder points of the heating element located on the LCD side of the circuit board.
    • Desolder these four connections using a soldering iron.
    • Note which wires go to each of the connection points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Heating Element Replacement: 步骤 7 中的图像 1,1
    • Solder the new heating element to the same connection points as they were removed from.
结论
Aaron Brysch
于11/06/17注册
231 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Harley Fall 2017 IUPUI, Team S1-G3, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S1G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 16
总计 2,183
