跳转到主内容
Apalus Digital Hair Straightening Brush Buttons Replacement
你所需要的
  1. Apalus Digital Hair Straightening Brush Buttons Replacement, Buttons on the side of the brush: 步骤 1 中的图像 1,1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Buttons Replacement: 步骤 2 中的图像 1,1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush Buttons Replacement: 步骤 3 中的图像 1,1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush Buttons Replacement: 步骤 5 中的图像 1,1
    • Locate the three buttons on the bottom side of the circuit board.
  6. Apalus Digital Hair Straightening Brush Buttons Replacement: 步骤 6 中的图像 1,1
    • Each button is soldered in four places on the circuit board. Using the soldering tool, melt each of these four points and remove the dysfunctional buttons.
    • You may have to bend the dark red capacitor out of the way to reach the soldering points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Buttons Replacement: 步骤 7 中的图像 1,1
    • Now that the dysfunctional buttons are removed, use a soldering tool and solder to install the new buttons on the circuit board.
    • Solder at the same four points as when previously melting these points to remove the buttons.
结论
另外一个人完成了本指南。
Aaron Brysch
于11/06/17注册
231 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Harley Fall 2017 IUPUI, Team S1-G3, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S1G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 19
总计 655
