跳转到主内容
加入维修社区 - 创建账户
Aoson R103 Speakers Replacement
浏览量: 745
浏览统计数据:
过去24小时
3
过去 7 天:
15
过去 30 天:
59
总计
745
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 1
1 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 15 - 45 分钟
难度: 困难
动态照片拍摄
成为一个动作片主人公!本指南需要一些图片,这些图片能够更好演示如何进行某些特定操作。
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片​​!
缺少的步骤
糟糕!本指南目前缺少一些重要的步骤。
This guide replaces Aoson R103 Speakers, which will require soldering. This guide can be used to fix distorted or broken audio and will require you to dismantle and redo electrical connections.
Be sure to disconnect the power from the battery to ensure you do not damage the device or injur yourself via electric shock. Exercise caution while soldering so that you do not burn anything.
你所需要的
工具
    1. Aoson R103 Speakers Replacement, Device: 步骤 1 中的图像 1,3 Aoson R103 Speakers Replacement, Device: 步骤 1 中的图像 2,3 Aoson R103 Speakers Replacement, Device: 步骤 1 中的图像 3,3
      • Turn off the device using the power button.
      • Using fingernails/a pry tool, separate the back panel of the device. This may require some force, as they are connected by push tabs.
      • Be careful not to drop the device when separating, as this could cause permanent damage.
      • This will expose the motherboard of the device.
      询问修复机器人
      添加评论
    2. Aoson R103 Speakers Replacement: 步骤 2 中的图像 1,2 Aoson R103 Speakers Replacement: 步骤 2 中的图像 2,2
      • Use your fingers to unclip the ribbon connector and then pull the ribbon out of the connector.
      • This ribbon connects the power button and stops the device from turning on.
      询问修复机器人
      添加评论
    1. Aoson R103 Speakers Replacement, Speakers: 步骤 3 中的图像 1,2 Aoson R103 Speakers Replacement, Speakers: 步骤 3 中的图像 2,2
      • These are the motherboard connections to the speaker, which will be needed later.
      • These are the two speakers, which are attached to a plastic piece via a screw.
      • Remove the 4.0mm long Phillips #00 screw where the plastic disconnects.
      • Be careful not to dislodge any of the wires behind the plastic piece when taking the plastic off.
      询问修复机器人
      添加评论
    2. Aoson R103 Speakers Replacement: 步骤 4 中的图像 1,2 Aoson R103 Speakers Replacement: 步骤 4 中的图像 2,2
      • The box contains the four (4) soldering connections for the two speakers. Desolder the old speakers and solder the new speakers in.
      • Be sure to match up the appropriately placed speaker to its correct positive or negative node. Mixing these up could distort audio or fry the speakers.
      • Solder over a piece of paper where you can mark each node with a red marker to denote positive nodes and black marker to denote negative nodes for the left or right speaker.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
作者
与
Louis
于02/14/23注册
208 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 59
总计 745
