跳转到主内容
Answering Machine Speaker Replacement
你所需要的
  1. Answering Machine Speaker Replacement, Base: 步骤 1 中的图像 1,1
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Answering Machine Speaker Replacement: 步骤 2 中的图像 1,2 Answering Machine Speaker Replacement: 步骤 2 中的图像 2,2
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Answering Machine Speaker Replacement, Answering Machine Speaker: 步骤 3 中的图像 1,2 Answering Machine Speaker Replacement, Answering Machine Speaker: 步骤 3 中的图像 2,2
    • Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
    • Use a screwdriver to remove the two 7mm Phillips #0 screws.
  4. Answering Machine Speaker Replacement: 步骤 4 中的图像 1,1
    • Finish speaker removal by cutting both the black and red wires.
  5. Answering Machine Speaker Replacement: 步骤 5 中的图像 1,1
结论
Troy Chester
于09/29/16注册
78 声望
撰写一个指南
团队
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S3G3
4 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 666
