跳转到主内容
加入维修社区 - 创建账户
Anki Vector LCD Facial Display Replacement
你所需要的
  1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: 步骤 1 中的图像 1,3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: 步骤 1 中的图像 2,3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: 步骤 1 中的图像 3,3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
  2. Anki Vector LCD Facial Display Replacement: 步骤 2 中的图像 1,3 Anki Vector LCD Facial Display Replacement: 步骤 2 中的图像 2,3 Anki Vector LCD Facial Display Replacement: 步骤 2 中的图像 3,3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
  3. Anki Vector LCD Facial Display Replacement: 步骤 3 中的图像 1,2 Anki Vector LCD Facial Display Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
  4. Anki Vector LCD Facial Display Replacement: 步骤 4 中的图像 1,2 Anki Vector LCD Facial Display Replacement: 步骤 4 中的图像 2,2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector LCD Facial Display Replacement: 步骤 5 中的图像 1,3 Anki Vector LCD Facial Display Replacement: 步骤 5 中的图像 2,3 Anki Vector LCD Facial Display Replacement: 步骤 5 中的图像 3,3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
结论
8等其他人完成本指南。
Shay Takei
于04/16/19注册
1,795 声望
创作了5篇指南
团队
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G6
4 名成员
创作了10篇指南
28指南评论
Any idea where to get the proper displays ?
Holger Brueckner - 回复 分享
xenojin - 回复 分享
This is great information, but where can I buy the display?
Jackie Fischvogt - 回复 分享
yeah I can’t find it anywhere.
Joel Choi - 分享
Does anyone have a line on display parts source?
warren williams - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 63
总计 12,718
