跳转到主内容
加入维修社区 - 创建账户
Anki Vector Capacitive Touch Sensor Replacement
你所需要的
  1. Anki Vector  Capacitive Touch Sensor Replacement, Belts: 步骤 1 中的图像 1,1
    • Raise Vector's arms above his head.
    询问修复机器人
    添加评论
  2. Anki Vector  Capacitive Touch Sensor Replacement: 步骤 2 中的图像 1,2 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 2 中的图像 2,2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
    询问修复机器人
    添加评论
  3. Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: 步骤 3 中的图像 1,3 Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: 步骤 3 中的图像 2,3 Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: 步骤 3 中的图像 3,3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
    添加评论
  4. Anki Vector  Capacitive Touch Sensor Replacement: 步骤 4 中的图像 1,3 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 4 中的图像 2,3 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 4 中的图像 3,3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
    添加评论
  5. Anki Vector  Capacitive Touch Sensor Replacement: 步骤 5 中的图像 1,2 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
    添加评论
  6. Anki Vector  Capacitive Touch Sensor Replacement: 步骤 6 中的图像 1,2 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 6 中的图像 2,2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
    询问修复机器人
    添加评论
  7. Anki Vector  Capacitive Touch Sensor Replacement: 步骤 7 中的图像 1,3 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 7 中的图像 2,3 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 7 中的图像 3,3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
    添加评论
  8. Anki Vector  Capacitive Touch Sensor Replacement, Capacitive Touch Sensor: 步骤 8 中的图像 1,2 Anki Vector  Capacitive Touch Sensor Replacement, Capacitive Touch Sensor: 步骤 8 中的图像 2,2
    • Using the Jimmy, insert the straight edge of the blade in recess groove in Vector's front wheel.
    • Slowly apply torque to the jimmy until the wheel cover pops off.
    • Repeat for the rear wheel.
    询问修复机器人
    添加评论
  9. Anki Vector  Capacitive Touch Sensor Replacement: 步骤 9 中的图像 1,2 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 9 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the two screws on the exposed wheels.
    • Once the screws are gone, remove the wheels from Vector's body.
    • Repeat this on the other side.
    询问修复机器人
    添加评论
  10. Anki Vector  Capacitive Touch Sensor Replacement: 步骤 10 中的图像 1,3 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 10 中的图像 2,3 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 10 中的图像 3,3
    • Gently remove the rear panel by griping it towards the top and pulling out and up.
    • Gently pull out the ribbon cable from the plug between the motherboard and the weight.
    询问修复机器人
    添加评论
  11. Anki Vector  Capacitive Touch Sensor Replacement: 步骤 11 中的图像 1,3 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 11 中的图像 2,3 Anki Vector  Capacitive Touch Sensor Replacement: 步骤 11 中的图像 3,3
    • Using a Phillips #0 screwdriver, unscrew the two screws located behind Vector's neck.
    • Lift the capacitive touch sensor assembly off of the body
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Shay Takei
于04/16/19注册
1,795 声望
创作了5篇指南
团队
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G6
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 52
总计 1,997
