跳转到主内容
加入维修社区 - 创建账户
Anki Vector Battery Replacement
你所需要的
  1. Anki Vector  Battery Replacement, LCD Facial Display: 步骤 1 中的图像 1,3 Anki Vector  Battery Replacement, LCD Facial Display: 步骤 1 中的图像 2,3 Anki Vector  Battery Replacement, LCD Facial Display: 步骤 1 中的图像 3,3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
    添加评论
  2. Anki Vector  Battery Replacement: 步骤 2 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 2 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 2 中的图像 3,3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
    添加评论
  3. Anki Vector  Battery Replacement: 步骤 3 中的图像 1,2 Anki Vector  Battery Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
    添加评论
  4. Anki Vector  Battery Replacement: 步骤 4 中的图像 1,2 Anki Vector  Battery Replacement: 步骤 4 中的图像 2,2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
    询问修复机器人
    添加评论
  5. Anki Vector  Battery Replacement: 步骤 5 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 5 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 5 中的图像 3,3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
    添加评论
  6. Anki Vector  Battery Replacement, Battery: 步骤 6 中的图像 1,3 Anki Vector  Battery Replacement, Battery: 步骤 6 中的图像 2,3 Anki Vector  Battery Replacement, Battery: 步骤 6 中的图像 3,3
    • Gently pull out the two halves of Vector's head from between his arms.
    添加评论
  7. Anki Vector  Battery Replacement: 步骤 7 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 7 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 7 中的图像 3,3
    • Remove the Anki Vector's belts on both sides of its body by gently sliding them off.
    • You should be able to pull them off without much effort.
    询问修复机器人
    添加评论
  8. Anki Vector  Battery Replacement: 步骤 8 中的图像 1,2 Anki Vector  Battery Replacement: 步骤 8 中的图像 2,2
    • Pull off the covers attached to Vector's rear wheels.
    询问修复机器人
    添加评论
  9. Anki Vector  Battery Replacement: 步骤 9 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 9 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 9 中的图像 3,3
    • Unscrew the 2 mm screws located under the wheel covers using a Phillips #0 screwdriver.
    • Remove the rear wheel.
    询问修复机器人
    添加评论
  10. Anki Vector  Battery Replacement: 步骤 10 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 10 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 10 中的图像 3,3
    • Unscrew the two 2 mm body screws using a Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  11. Anki Vector  Battery Replacement: 步骤 11 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 11 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 11 中的图像 3,3
    • Using two fingers gently pull off the lower rear panel.
    • Using your fingers, unplug the ribbon connector.
    询问修复机器人
    添加评论
  12. Anki Vector  Battery Replacement: 步骤 12 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 12 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 12 中的图像 3,3
    • Unscrew the two screws behind vector's neck.
    • Remove the capacitive touch assembly.
    添加评论
  13. Anki Vector  Battery Replacement: 步骤 13 中的图像 1,2 Anki Vector  Battery Replacement: 步骤 13 中的图像 2,2
    • With a moderate amount of force pull one of vector's top arms away from his body until it disconnects from the shaft.
    添加评论
  14. Anki Vector  Battery Replacement: 步骤 14 中的图像 1,2 Anki Vector  Battery Replacement: 步骤 14 中的图像 2,2
    • Gripping the shaft with needle nosed pliers, pull the opposite top arm off the main shaft.
    询问修复机器人
    添加评论
  15. Anki Vector  Battery Replacement: 步骤 15 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 15 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 15 中的图像 3,3
    • Pinch one end of the arm shaft and push it into the body.
    • Grab the other end and pull the shaft out of the body.
    添加评论
  16. Anki Vector  Battery Replacement: 步骤 16 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 16 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 16 中的图像 3,3
    • Raise vectors arms all the way up and gently pull each arm out of its socket.
    询问修复机器人
    添加评论
  17. Anki Vector  Battery Replacement: 步骤 17 中的图像 1,2 Anki Vector  Battery Replacement: 步骤 17 中的图像 2,2
    • Pull the wheel covers off of Vectors forward wheels.
    询问修复机器人
    添加评论
  18. Anki Vector  Battery Replacement: 步骤 18 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 18 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 18 中的图像 3,3
    • Using the same Phillips #0 screwdriver, unscrew the 2 mm screw under the wheel cover.
    • Gently pull the wheel off.
    询问修复机器人
    添加评论
  19. Anki Vector  Battery Replacement: 步骤 19 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 19 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 19 中的图像 3,3
    • Unscrew the two body screws located behind the front wheels.
    • Gently pull the cover from Vector's body
    • Be careful when removing the cover. The infrared sensor connects the cover to the body by wires.
    询问修复机器人
    添加评论
  20. Anki Vector  Battery Replacement: 步骤 20 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 20 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 20 中的图像 3,3
    • Gently unplug and remove the infrared sensor.
    询问修复机器人
    添加评论
  21. Anki Vector  Battery Replacement: 步骤 21 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 21 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 21 中的图像 3,3
    • Insert your Phillips #0 bit into a 4 mm nut driver and insert both into your bit driver.
    • Unscrew the three body screws.
    询问修复机器人
    添加评论
  22. Anki Vector  Battery Replacement: 步骤 22 中的图像 1,2 Anki Vector  Battery Replacement: 步骤 22 中的图像 2,2
    • Gradually increasing applied force, pull the body apart.
    添加评论
  23. Anki Vector  Battery Replacement: 步骤 23 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 23 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 23 中的图像 3,3
    • Remove the shoulder panel.
    • Remove the weight.
    询问修复机器人
    添加评论
  24. Anki Vector  Battery Replacement: 步骤 24 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 24 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 24 中的图像 3,3
    • Unplug the two motor connectors from the motherboard.
    添加评论
  25. Anki Vector  Battery Replacement: 步骤 25 中的图像 1,3 Anki Vector  Battery Replacement: 步骤 25 中的图像 2,3 Anki Vector  Battery Replacement: 步骤 25 中的图像 3,3
    • Wriggle the battery free from the motherboard.
    • Using a soldering iron, desolder the connections from the battery to the motherboard.
    添加评论
结论
取消:我没有完成这个指南。
46等其他人完成本指南。
Shay Takei
于04/16/19注册
1,795 声望
创作了5篇指南
团队
Cal Poly, Team S2-G6, Maness Spring 2019 Cal Poly, Team S2-G6, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G6
4 名成员
创作了10篇指南
25指南评论
Ok nice step by step guide but what are the specs for the battery as they’re not visable in any of the pictures…
John Fitzgerald - 回复 分享
Part Number: Li-Ion Poly 500mAh #1578B
3.7V 500mAh
Brian - 回复 分享
Who manages to do all of this in 7 minutes ? Apparently it is a 3.7V battery, question is what is the max size that fits ? 3.5 x 2.5 x 0.4 cm is reported to fit, 4x3x0.5 might as well.
Holger Brueckner - 回复 分享
Any idea where to get one ?
Gordon Hamilton - 回复 分享
Who manages to do all of this is 7 minutes?
me
Kerigan Creighton - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 106
过去 30 天: 440
总计 34,411
