跳转到主内容
Anker SoundCore 2 Speaker Replacement
你所需要的
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: 步骤 1 中的图像 1,2 Anker SoundCore 2 Speaker Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Speaker Replacement, Speaker: 步骤 2 中的图像 1,3 Anker SoundCore 2 Speaker Replacement, Speaker: 步骤 2 中的图像 2,3 Anker SoundCore 2 Speaker Replacement, Speaker: 步骤 2 中的图像 3,3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Speaker Replacement: 步骤 3 中的图像 1,3 Anker SoundCore 2 Speaker Replacement: 步骤 3 中的图像 2,3 Anker SoundCore 2 Speaker Replacement: 步骤 3 中的图像 3,3
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
结论
另外一个人完成了本指南。
9条评论
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - 回复
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - 回复
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez -
Do someone get a new speaker? I need to buy one!
everton.euclides - 回复
jafarez -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 37
过去 30 天: 125
总计 4,171
