跳转到主内容
Android tablet Nobis NB09 Speaker Replacement
你所需要的
  1. Android tablet Nobis NB09 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the two 00 Phillips screws located in the right hand side of the tablet.
  2. Android tablet Nobis NB09 Speaker Replacement: 步骤 2 中的图像 1,3 Android tablet Nobis NB09 Speaker Replacement: 步骤 2 中的图像 2,3 Android tablet Nobis NB09 Speaker Replacement: 步骤 2 中的图像 3,3
    • Use plastic opening tools to loosen and pry off the back plate (pink piece).
    • When removing the cover, be careful not to pull too hard as there are wires connected to the motherboard attached to the back cover.
  3. Android tablet Nobis NB09 Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Android tablet Nobis NB09 Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge).
    • The speaker is located on the top left hand side of the tablet.
    • Remove the electrical tape covering the connections to expose the wires.
  4. Android tablet Nobis NB09 Speaker Replacement: 步骤 4 中的图像 1,1
    • Disconnect the faulty speaker by desoldering the two wire connections.
    • Make sure to not damage the motherboard.
  5. Android tablet Nobis NB09 Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the tape holding the speaker in its socket.
  6. Android tablet Nobis NB09 Speaker Replacement: 步骤 6 中的图像 1,2 Android tablet Nobis NB09 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the speaker from its socket. Placing the speaker to the side of your device will give you more freedom.
    • Gently pushing the speaker from the back side of the cover with a pointy edge of spudger tool will make this step easier.
  7. Android tablet Nobis NB09 Speaker Replacement: 步骤 7 中的图像 1,2 Android tablet Nobis NB09 Speaker Replacement: 步骤 7 中的图像 2,2
    • Use a soldering iron to extract excess solder using a desoldering braid.
    • Solder the speakers wires back to the motherboard.
    • Review the iFixit soldering guide for help with soldering.
    • Connect red wire to the positive terminal marked "+", and the black wire to the negative terminal marked "-".
结论
To reassemble your device, follow these instructions in reverse order. Do not forget to put electrical tape back in place.
2等其他人完成本指南。
Sergey Kasyanov
于03/26/15注册
237 声望
创作了2篇指南
团队
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 647
