跳转到主内容
Anbernic RG353V Circuit Board Replacement
你所需要的
  1. Anbernic RG353V Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,3 Anbernic RG353V Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 2,3 Anbernic RG353V Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 3,3
    • Make sure to remove the SD cards from the device before repair. Push them inwards so that they pop out of their respective slots.
    • Use a 2 mm Hex screwdriver to remove the six 7 mm screws from the back case of the handheld game.
    • Use an opening tool to pry the top and bottom of the game apart. Work the tool around the perimeter of the device between the seam to release the snap tabs.
    • Separate the top and bottom cases gently.
    • Don't pull them apart as they are connected by cables and pulling them could rip the wires and damage the device.
  2. Anbernic RG353V Circuit Board Replacement: 步骤 2 中的图像 1,3 Anbernic RG353V Circuit Board Replacement: 步骤 2 中的图像 2,3 Anbernic RG353V Circuit Board Replacement: 步骤 2 中的图像 3,3
    • Push on alternating sides of the connector to disconnect the battery wire from the main circuit board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • To disconnect the cable coaxial cable, slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
    • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
    • Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    • Don't try to force the connector into place or you may permanently damage it.
    • Disconnecting these wires will allow you to separate the back of the case from the front in order to work more freely.
  3. Anbernic RG353V Circuit Board Replacement: 步骤 3 中的图像 1,2 Anbernic RG353V Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the five 7 mm Phillips from the plate covering the bottom of the circuit board.
    • Remove the black cover.
    • The next three steps after this one can be done in any order.
  4. Anbernic RG353V Circuit Board Replacement: 步骤 4 中的图像 1,2 Anbernic RG353V Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 to remove the four 6 mm screws attaching the thumbsticks to the circuit board.
    • Use a spudger to flip up the locking flaps of the ZIF connectors.
    • Use tweezers or your fingers to gently pull the red ribbon cables out of their sockets.
  5. Anbernic RG353V Circuit Board Replacement: 步骤 5 中的图像 1,3 Anbernic RG353V Circuit Board Replacement: 步骤 5 中的图像 2,3 Anbernic RG353V Circuit Board Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to flip up the locking flap of the ZIF connector.
    • Use tweezers or your fingers to gently pull the bronze-colored ribbon cable out of its socket.
    • Use tweezers or your fingers to remove the small black ribbon cable from the socket.
    • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  6. Anbernic RG353V Circuit Board Replacement: 步骤 6 中的图像 1,2 Anbernic RG353V Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 5 mm screws that secure the circuit board to the case.
  7. Anbernic RG353V Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the circuit board by pulling it upward and away from the case.
    • Gently thread the two ribbon cables through the slot to avoid damage.
结论
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
2等其他人完成本指南。
Konnor
于09/09/24注册
649 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 60
总计 576
