跳转到主内容
Amazon Kindle DX Previous Page Key Replacement
你所需要的
  1. Amazon Kindle DX Previous Page Key Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the Kindle so the back is facing upwards.
  2. Amazon Kindle DX Previous Page Key Replacement: 步骤 2 中的图像 1,1
    • Push an opening tool against the bottom cover edge of the device. Move the tool's edge around the bottom plastic piece to pop it open.
  3. Amazon Kindle DX Previous Page Key Replacement: 步骤 3 中的图像 1,1
    • Remove the plastic piece.
  4. Amazon Kindle DX Previous Page Key Replacement: 步骤 4 中的图像 1,2 Amazon Kindle DX Previous Page Key Replacement: 步骤 4 中的图像 2,2
    • Remove two 40 mm screws (one on each corner) using a Phillips #00 screwdriver.
  5. Amazon Kindle DX Previous Page Key Replacement: 步骤 5 中的图像 1,2 Amazon Kindle DX Previous Page Key Replacement: 步骤 5 中的图像 2,2
    • Use the edges of the opening tool, get in between the seams of the front and back panel, and use the tool to separate the pieces. Once loose, lift back panel off of the device.
  6. Amazon Kindle DX Previous Page Key Replacement: 步骤 6 中的图像 1,2 Amazon Kindle DX Previous Page Key Replacement: 步骤 6 中的图像 2,2
    • Remove two 30 mm screws securing the battery with a Phillips #00 screwdriver.
  7. Amazon Kindle DX Previous Page Key Replacement: 步骤 7 中的图像 1,2 Amazon Kindle DX Previous Page Key Replacement: 步骤 7 中的图像 2,2
    • Remove the battery from the device.
  8. Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: 步骤 8 中的图像 1,3 Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: 步骤 8 中的图像 2,3 Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: 步骤 8 中的图像 3,3
    • Remove five 30 mm screws from the midframe using a Phillips #000 screwdriver.
  9. Amazon Kindle DX Previous Page Key Replacement: 步骤 9 中的图像 1,1
    • Remove the midframe to reveal the motherboard.
  10. Amazon Kindle DX Previous Page Key Replacement: 步骤 10 中的图像 1,2 Amazon Kindle DX Previous Page Key Replacement: 步骤 10 中的图像 2,2
    • Remove the "previous page" button from the side function keys using a pair of tweezers.
结论
Lori White
于09/28/16注册
557 声望
创作了3篇指南
团队
USF Tampa, Team 1-5, Cagle Fall 2016 USF Tampa, Team 1-5, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G5
3 名成员
创作了8篇指南
2条评论
The title says “keyboard”, this is button replacement…………….
Robert Clayworth - 回复
The title says “keyboard” replacement. This is button replacement…………….
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 17
总计 1,133
