跳转到主内容
Amazon Kindle 8 Power Button Replacement
你所需要的
  1. Amazon Kindle 8 Power Button Replacement, Front Cover: 步骤 1 中的图像 1,2 Amazon Kindle 8 Power Button Replacement, Front Cover: 步骤 1 中的图像 2,2
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Power Button Replacement: 步骤 2 中的图像 1,2 Amazon Kindle 8 Power Button Replacement: 步骤 2 中的图像 2,2
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
  3. Amazon Kindle 8 Power Button Replacement, Motherboard: 步骤 3 中的图像 1,2 Amazon Kindle 8 Power Button Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
  4. Amazon Kindle 8 Power Button Replacement: 步骤 4 中的图像 1,2 Amazon Kindle 8 Power Button Replacement: 步骤 4 中的图像 2,2
    • Lift the screen and motherboard from the back cover.
  5. Amazon Kindle 8 Power Button Replacement, Power Button: 步骤 5 中的图像 1,2 Amazon Kindle 8 Power Button Replacement, Power Button: 步骤 5 中的图像 2,2
    • On the back cover, from the outside of the kindle, use your finger to push the power button through its hole.
    • Remove the power button.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
于09/25/24注册
432 声望
创作了5篇指南
团队
1指南评论
partial fix, that does not show how to remove and replace the button in the subject. Please integrate step-by-step guide.
SimoneGallina - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 66
总计 546
