跳转到主内容
加入维修社区 - 创建账户
Amazon Kindle 8 Back Cover Replacement
你所需要的
  1. Amazon Kindle 8 Back Cover Replacement, Front Cover: 步骤 1 中的图像 1,2 Amazon Kindle 8 Back Cover Replacement, Front Cover: 步骤 1 中的图像 2,2
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the front cover gently so that it is not cracked.
  2. Amazon Kindle 8 Back Cover Replacement: 步骤 2 中的图像 1,2 Amazon Kindle 8 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Insert the spudger between the inner front cover and the screen.
    • Gently work your way around to loosen the inner front cover.
    • Carefully lift the inner front cover from the device.
  3. Amazon Kindle 8 Back Cover Replacement, Motherboard: 步骤 3 中的图像 1,2 Amazon Kindle 8 Back Cover Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
  4. Amazon Kindle 8 Back Cover Replacement: 步骤 4 中的图像 1,2 Amazon Kindle 8 Back Cover Replacement: 步骤 4 中的图像 2,2
    • Lift the screen and motherboard from the back cover.
  5. Amazon Kindle 8 Back Cover Replacement, Back Cover: 步骤 5 中的图像 1,1
    • Separate the motherboard and the back cover.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
于09/25/24注册
432 声望
创作了5篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 46
总计 548
