跳转到主内容
Amazon Fire TV Power Cord Port Replacement
你所需要的
  1. Amazon Fire TV Power Cord Port Replacement, Motherboard: 步骤 1 中的图像 1,3 Amazon Fire TV Power Cord Port Replacement, Motherboard: 步骤 1 中的图像 2,3 Amazon Fire TV Power Cord Port Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Place the plastic opening tool in the space between the rubber and the plastic case of the device.
    • Apply pressure by pushing upward on the case.
    • Separate the bottom square rubber piece from the case using the plastic opening tool until all clips are detached.
  2. Amazon Fire TV Power Cord Port Replacement: 步骤 2 中的图像 1,2 Amazon Fire TV Power Cord Port Replacement: 步骤 2 中的图像 2,2
    • Locate the ten J#00 Phillips screws and remove them.
  3. Amazon Fire TV Power Cord Port Replacement: 步骤 3 中的图像 1,3 Amazon Fire TV Power Cord Port Replacement: 步骤 3 中的图像 2,3 Amazon Fire TV Power Cord Port Replacement: 步骤 3 中的图像 3,3
    • Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case.
  4. Amazon Fire TV Power Cord Port Replacement, Power Cord Port: 步骤 4 中的图像 1,3 Amazon Fire TV Power Cord Port Replacement, Power Cord Port: 步骤 4 中的图像 2,3 Amazon Fire TV Power Cord Port Replacement, Power Cord Port: 步骤 4 中的图像 3,3
    • With the mother board back facing you locate the power cord port found on the far left end.
  5. Amazon Fire TV Power Cord Port Replacement: 步骤 5 中的图像 1,3 Amazon Fire TV Power Cord Port Replacement: 步骤 5 中的图像 2,3 Amazon Fire TV Power Cord Port Replacement: 步骤 5 中的图像 3,3
    • Locate the four soldering joints for the power cord port found on the top side of the mother board.
    • Desolder the joints of the power cord port to release it from the motherboard.
    • Place the new power cord port into its original location and solder its joints.
    • Use the iFixit soldering and desoldering guide.
结论
5等其他人完成本指南。
jeffrey555
于09/01/15注册
424 声望
创作了2篇指南
团队
USF Tampa, Team 16-3, Wollert Fall 2015 USF Tampa, Team 16-3, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G3
4 名成员
创作了16篇指南
2条评论
Aonde compro essa fonte ? wagnerj957@gmail.com
wagnerjr1977 - 回复
Ola moro no Brasil minha fonte queimou aonde compro outra?
wagnerjr1977 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 28
总计 2,766
