跳转到主内容
Amazon Fire 5th Generation Speaker Replacement
你所需要的
  1. Amazon Fire 5th Generation Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Amazon Fire 5th Generation Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Ensure that your device is turned off.
    • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
    • While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
    • Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
    • Then, remove the back cover from the device.
  2. Amazon Fire 5th Generation Speaker Replacement: 步骤 2 中的图像 1,2 Amazon Fire 5th Generation Speaker Replacement: 步骤 2 中的图像 2,2
    • Pry the speaker from the case using the iFixit Opening Tool.
    • Lift the speaker up from the device to remove the speaker wires from their groove in the case.
    • Be careful not to pull the speaker wires from the motherboard.
  3. Amazon Fire 5th Generation Speaker Replacement: 步骤 3 中的图像 1,3 Amazon Fire 5th Generation Speaker Replacement: 步骤 3 中的图像 2,3 Amazon Fire 5th Generation Speaker Replacement: 步骤 3 中的图像 3,3
    • Desolder the speaker wires from the motherboard.
    • iFixit has a helpful guide explaining how to solder and desolder here: 如何焊接和拆焊
结论
另外一个人完成了本指南。
Amber Bunch
于02/10/16注册
1,391 声望
创作了3篇指南
团队
USF Tampa, Team 1-2, Nance Spring 2016 USF Tampa, Team 1-2, Nance Spring 2016 的会员
USFT-NANCE-S16S1G2
3 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,379
