跳转到主内容
Amazon Echo Show 8 2nd Generation Speaker Replacement
你所需要的
  1. Amazon Echo Show 8 2nd Generation Speaker Replacement, Rear Case: 步骤 1 中的图像 1,3 Amazon Echo Show 8 2nd Generation Speaker Replacement, Rear Case: 步骤 1 中的图像 2,3 Amazon Echo Show 8 2nd Generation Speaker Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 2 中的图像 1,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 2 中的图像 2,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 2 中的图像 3,3
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 3 中的图像 1,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 3 中的图像 2,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 3 中的图像 3,3
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 4 中的图像 1,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 4 中的图像 2,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 4 中的图像 3,3
    • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
  5. Amazon Echo Show 8 2nd Generation Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Amazon Echo Show 8 2nd Generation Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Amazon Echo Show 8 2nd Generation Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Use a T6 Torx screwdriver to remove the five 5.2 mm screws that secure the power board.
  6. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 6 中的图像 1,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 6 中的图像 2,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 6 中的图像 3,3
    • Use a T6 Torx screwdriver to remove the six 7.6 mm screws that secure the speaker housing to the display assembly.
    • There is a sixth screw at the bottom between the two outside screws not shown in this image.
  7. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 7 中的图像 1,1
    • Gently separate the speaker housing from the front section like opening a book.
    • Lay the display assembly face down.
    • Take care when separating the two sections to avoid straining or damaging the speaker connector.
  8. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 8 中的图像 1,2 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to gently push the speaker connector directly out of its port.
    • Make sure not to apply excessive force as doing so will damage the female connector
  9. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 9 中的图像 1,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 9 中的图像 2,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 9 中的图像 3,3
    • Use metal spudger to gently peel back part of the copper heat shield to reveal two 9 mm Phillips screws.
  10. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 10 中的图像 1,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 10 中的图像 2,3 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 10 中的图像 3,3
    • Use a Philips screwdriver to remove the fourteen 9 mm screws from the speaker housing cover.
    • Remove the speaker housing cover.
  11. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 11 中的图像 1,2 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips screwdriver to remove the four 9 mm screws that secure the driver.
    • Repeat this step for the driver on the opposite side.
  12. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 12 中的图像 1,2 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 12 中的图像 2,2
    • Insert a spudger between the driver and the housing and gently pry it away.
    • A considerable amount of force may be required at this step due to the adhesive holding the speaker to the housing.
  13. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 13 中的图像 1,1
    • Lift the driver cable out from the retention clips.
  14. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 14 中的图像 1,2 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 14 中的图像 2,2
    • Gently peel the motherboard connector away from the speaker housing.
    • The cable is held down with adhesive. Be gentle when lifting it to avoid damage.
  15. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 15 中的图像 1,1
    • Push the speaker connector through the speaker housing.
    • The rubber gromet that holds the cable may be difficult to remove. Use a gentle pushing and pulling motion to easily remove it.
  16. Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 16 中的图像 1,2 Amazon Echo Show 8 2nd Generation Speaker Replacement: 步骤 16 中的图像 2,2
    • Remove the drivers.
结论
2等其他人完成本指南。
Brian Le
于02/14/24注册
681 声望
创作了4篇指南
1指南评论
What speakers can be used to replace the originals? Mine are gone .
Ernesto Guantes V - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 50
总计 954
