简介
Use this replacement guide if the speakers of the Amazon Echo Show 8 are not functioning or you are experiencing crunchy or distorted audio audio. The speaker is important to the device so you can hear music and movies that are streaming on your device. Before continuing with this replacement guide, go to the troubleshooting guide and ensure you have completed the troubleshooting steps. This guide will walk you through the process of replacing the speaker. Make sure the device is disconnected from the power before proceeding with the guide.
你所需要的
Flip the device so that the rubber foot is facing up.
Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
Remove the rubber foot.
Use a T6 Torx screwdriver to remove the five 5.25 mm screws that secure the power board.
