简介
Use this replacement guide if the motherboard of the Amazon Echo Show 8 is not functioning. The motherboard is important to the device because it ensures it can internally function overall. Before continuing with this replacement guide check out the troubleshooting guide and see if any of the problems your facing could be fixed via trouble shooting. There are two components when powering the device, the port and the cord. This guide will walk you through replacing the mother. Make sure the device is disconnected from the power before proceeding with the guide.
你所需要的
Flip the device so that the rubber foot is facing up.
Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
Remove the rubber foot.
Use a T6 Torx screwdriver to remove the six 7.6 mm screws that secure the speaker housing to the display assembly.
Use the pointed end of a spudger to flip up the both of the ZIF locking flaps. Gently pull both of the cables out of their respective ports.
Flip up the locking flap OPPOSITE of the cable, i.e., the other side from the previous cables.
Remove the speaker connector by pushing it away from the motherboard with the pointed end of a spudger.
