跳转到主内容
Amazon Echo Show 8 2nd Generation Microphone Board Replacement
你所需要的
  1. Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Rear Case: 步骤 1 中的图像 1,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Rear Case: 步骤 1 中的图像 2,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 2 中的图像 1,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 2 中的图像 2,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 2 中的图像 3,3
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 3 中的图像 1,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 3 中的图像 2,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 3 中的图像 3,3
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 4 中的图像 1,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 4 中的图像 2,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 4 中的图像 3,3
    • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
  5. Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Microphone: 步骤 5 中的图像 1,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Microphone: 步骤 5 中的图像 2,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement, Microphone: 步骤 5 中的图像 3,3
    • Orient the Echo with the microphone board facing upwards.
    • Use a spudger to gently remove the 2 pieces of foam covering the ribbon cables.
  6. Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 6 中的图像 1,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 6 中的图像 2,3 Amazon Echo Show 8 2nd Generation Microphone Board Replacement: 步骤 6 中的图像 3,3
    • Use the pointed end of a spudger to flip up both of the ZIF locking flaps.
    • Gently remove both of the ribbon cables from their respective sockets.
    • Lift the micro
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 511
