简介
This guide will walk you through the replacement process for the power jack found within your Amazon Echo Show 10 3rd Gen device. The power jack and its related components are responsible for providing a steady supply of power to the device from its accompanying plug in the wall. If you are having issues with your Echo device not turning on or powering off unexpectedly, there may be an issue with the power jack within the device, and may need replacement.
Make sure other solutions found within the Amazon Echo Show 10 3rd Gen troubleshooting page(such as checking the outlet plug or power cord for damage) have been attempted before committing to disassembly and replacement.
Before you begin the repair, power off and disconnect your device from the power outlet.
你所需要的
With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
Remove the lid and set it aside.
