跳转到主内容
加入维修社区 - 创建账户
Amazon Echo Look Front Panel Replacement
你所需要的
  1. Amazon Echo Look Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
  2. Amazon Echo Look Front Panel Replacement: 步骤 2 中的图像 1,3 Amazon Echo Look Front Panel Replacement: 步骤 2 中的图像 2,3 Amazon Echo Look Front Panel Replacement: 步骤 2 中的图像 3,3
    • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
  3. Amazon Echo Look Front Panel Replacement: 步骤 3 中的图像 1,1
    • Heat the front panel with an iOpener.
    • It may help to secure the iOpener to the device.
    • Heat the device for 5-10 minutes to loosen the glue.
    • CAUTION: The iOpener and the device may be hot.
  4. Amazon Echo Look Front Panel Replacement: 步骤 4 中的图像 1,3 Amazon Echo Look Front Panel Replacement: 步骤 4 中的图像 2,3 Amazon Echo Look Front Panel Replacement: 步骤 4 中的图像 3,3
    • Lever the Jimmy between the screen and the device until an opening is formed.
    • Insert opening picks to hold the opening as needed.
    • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
    • Step 3 may need to be repeated as Step 4 is time-sensitive.
  5. Amazon Echo Look Front Panel Replacement: 步骤 5 中的图像 1,2 Amazon Echo Look Front Panel Replacement: 步骤 5 中的图像 2,2
    • Remove the front panel by levering the spudger at the top of the device.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 151
