跳转到主内容
Altec Lansing inMotion iM9 Volume and Power Buttons Replacement
你所需要的
  1. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Battery: 步骤 1 中的图像 1,1
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 步骤 2 中的图像 1,1
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: 步骤 3 中的图像 1,2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: 步骤 3 中的图像 2,2
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 步骤 4 中的图像 1,2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 步骤 5 中的图像 1,2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 步骤 5 中的图像 2,2
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
结论
Ben Toland
于02/01/15注册
101 声望
撰写一个指南
团队
Cal Poly, Team 17-33, Amido Winter 2015 Cal Poly, Team 17-33, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G33
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 13
总计 2,461
