跳转到主内容
Altec Lansing OVO Bluetooth Speaker Disassembly
你所需要的
  1. Altec Lansing OVO Bluetooth Speaker Disassembly, Altec Lansing OVO Bluetooth Speaker Disassembly: 步骤 1 中的图像 1,1
    • This is the unit that we are going to disassemble.
  2. Altec Lansing OVO Bluetooth Speaker Disassembly: 步骤 2 中的图像 1,1
    • Screws approximate location behind the front cover.
  3. Altec Lansing OVO Bluetooth Speaker Disassembly: 步骤 3 中的图像 1,1
    • Use a pick to gently pull the cover. There are no fragile parts. The cover is made of metal and covered with a type of mesh.
  4. Altec Lansing OVO Bluetooth Speaker Disassembly: 步骤 4 中的图像 1,3 Altec Lansing OVO Bluetooth Speaker Disassembly: 步骤 4 中的图像 2,3 Altec Lansing OVO Bluetooth Speaker Disassembly: 步骤 4 中的图像 3,3
    • Once the front cover is removed gently lift the thin protection layer in order to find the holes where the screws are located. In order to find the two middle screws you will have to make two small incisions as shown in the picture.
  5. Altec Lansing OVO Bluetooth Speaker Disassembly: 步骤 5 中的图像 1,2 Altec Lansing OVO Bluetooth Speaker Disassembly: 步骤 5 中的图像 2,2
    • After you remove the 13 screws, put your finger in the woofer hole on the back of the speaker. Pull gently outwards to make sure you don't break the flat cable that connects the back to the main board. And that's it! Now you have full access to all the inner parts of your speaker.
结论
由衷感谢以下译者:
pt en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Nuno
于03/02/22注册
181 声望
撰写一个指南
1指南评论
What is the spec on the battery in this unit (Altec Lansing OVO AL-BT42S)?
Hugo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 48
总计 1,513
