跳转到主内容
加入维修社区 - 创建账户
Alldaymall A88X Speaker Replacement
你所需要的
  1. Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 1,3 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 2,3 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Speaker Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Speaker Replacement, Speaker: 步骤 3 中的图像 1,3 Alldaymall A88X Speaker Replacement, Speaker: 步骤 3 中的图像 2,3 Alldaymall A88X Speaker Replacement, Speaker: 步骤 3 中的图像 3,3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Speaker Replacement: 步骤 4 中的图像 1,3 Alldaymall A88X Speaker Replacement: 步骤 4 中的图像 2,3 Alldaymall A88X Speaker Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Speaker Replacement: 步骤 5 中的图像 1,3 Alldaymall A88X Speaker Replacement: 步骤 5 中的图像 2,3 Alldaymall A88X Speaker Replacement: 步骤 5 中的图像 3,3
    • Desolder the speaker wires from the motherboard.
结论
Drhaber
于02/10/16注册
985 声望
创作了7篇指南
团队
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 的会员
USFT-LACY-S16S4G1
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 400
