跳转到主内容
加入维修社区 - 创建账户
Alldaymall A88X Battery Replacement
你所需要的
  1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 1,3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 2,3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
    询问修复机器人
  2. Alldaymall A88X Battery Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
    询问修复机器人
  3. Alldaymall A88X Battery Replacement, Battery: 步骤 3 中的图像 1,3 Alldaymall A88X Battery Replacement, Battery: 步骤 3 中的图像 2,3 Alldaymall A88X Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
    询问修复机器人
  4. Alldaymall A88X Battery Replacement: 步骤 4 中的图像 1,3 Alldaymall A88X Battery Replacement: 步骤 4 中的图像 2,3 Alldaymall A88X Battery Replacement: 步骤 4 中的图像 3,3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
    询问修复机器人
  5. Alldaymall A88X Battery Replacement: 步骤 5 中的图像 1,2 Alldaymall A88X Battery Replacement: 步骤 5 中的图像 2,2
    • Desolder the wires that connect the battery to the motherboard.
    询问修复机器人
结论
4等其他人完成本指南。
Alex
于02/10/16注册
101 声望
撰写一个指南
团队
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016 的会员
USFT-LACY-S16S4G1
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 51
总计 1,527
