跳转到主内容
Alcatel Pop 4 Plus Headphone Jack Replacement
你所需要的
  1. Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,3 Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 2,3 Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 3,3
    • Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
  2. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 2 中的图像 1,3 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 2 中的图像 2,3 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Remove seventeen 1.2mm screws from the phone's mid-frame using the Phillips #000 screwdriver.
  3. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 3 中的图像 1,2 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Once the screws have been taken out, remove the mid-frame protecting the phone's electronics by using a fingernail or tool to pry it off.
  4. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 4 中的图像 1,3 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 4 中的图像 2,3 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 4 中的图像 3,3
    • Disconnect the battery from the motherboard and remove it.
  5. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 5 中的图像 1,2 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Unhook the USB ribbon from the motherboard.
  6. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 6 中的图像 1,2 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 6 中的图像 2,2
    • Disconnect the phone's ribbon cable from the mother board.
  7. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 7 中的图像 1,2 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 7 中的图像 2,2
    • Disconnect the ribbon cable that binds the two motherboards together.
  8. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 8 中的图像 1,2 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 8 中的图像 2,2
    • Remove the phone's rear camera from the motherboard.
  9. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 9 中的图像 1,1
    • Insert a flat tool at the edge of the phone and gently lift to remove the motherboard.
  10. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 10 中的图像 1,3 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 10 中的图像 2,3 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 10 中的图像 3,3
    • Locate the phone's headphone jack on the motherboard.
  11. Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 11 中的图像 1,3 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 11 中的图像 2,3 Alcatel Pop 4 Plus Headphone Jack Replacement: 步骤 11 中的图像 3,3
结论
Garett Marler
于09/19/19注册
202 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 165
